-   -   cometic head gaskets have you tried them......... (https://www.racingjunk.com/forums/showthread.php?t=24882)
dparker 07-10-2009 07:33 AM
I pulled my heads and only have .005 clearance valve to piston. I'm thinking about going from a .039 head gasket to a .080 Cometic. I like everything I've heard so far just making sure none of you have any horror stories with these gaskets.......
TS1955 07-10-2009 08:05 AM
I've been using them for about 5 years on Harley engines and they work great. Haven't had a problem yet. I would recommend them.
TS1955
hammertime 07-10-2009 08:20 AM
I use them, they have been reused 3 times now also :D
kwkracing 07-10-2009 08:29 AM
Interesting... i have a motor that needs more clearance also.... but are you sure there is a .080" head gasket? I looked on there web page and did not see anything offered but .040.
Thanks, keith
dparker 07-10-2009 09:53 AM
I called today they can make up to .140 thick, custom.
oldandtired 07-10-2009 10:26 AM
Excellent gaskets. The reason you can get so many thicknesses, is that they keep stacking layers until it arrives at the thickness you want.
Not for use with O ringed block.
Dave
kwkracing 07-10-2009 12:41 PM
How much are the .080 going to cost?
fla1976 07-10-2009 12:43 PM
Gaskets
I tried cometics after having problems with gaskets leaking. Never had a problem with a head gasket after that. They are expensive, but well worth the money in my opinion. Still have the copper gaskets hanging in the garage. :idea:
dparker 07-10-2009 03:50 PM
$119.95 each
kwkracing 07-10-2009 05:55 PM
Does anyone think there is a issue with the intake sealing or alligning when using a .080 gasket? Do they suggest a thicker intake gaskets?
In my case the deck surface is not cut down, my stroke and piston come .010 out of the hole.....i know.... it was all stuff that i had layin around.
Dparker i appologize im not trying to take your thread, just use it to grow more knowledge upon :?
