-   -   BBC Blown Injected Engine (https://www.racingjunk.com/forums/showthread.php?t=24871)
wildrod 07-08-2009 05:50 PM
Working with a friend on his willys. 502 blown, injected chevy. Now the problem, car starts, runs fine until its up to temp. When shut off, it will not start until it cools down. Motor turns when hot but will not fire. Fuel pressure 50psi when cranking. removed blower today to replace magnetic pickup in distributor. Can't get at the cap with blower in place. Have spark at plugs. Car still will not fire when hot, let it sit till it cools and it fires immediately. Could this be a bad coil????? OR WHAT ELSE, MY BUDDY IS GOING CRAZY!!!!!!!!
jreiley 07-09-2009 12:40 PM
This problem was talked about in another thread somewhere. The suggestion was that the static compression may be too low. I have a blown bbc car, have not had this problem.
kwkracing 07-09-2009 05:57 PM
What kind of injection, i am assuming electronic not mechanical? Will it try to fire hot if you dump fuel in the hat? Are you just assuming its loosing spark?
Need to know more about what kind of set up you have
zipper06 07-09-2009 06:38 PM
X2, he said it had spark at the plugs, i've ran as low as 8.0 to one but with a short cam duration, no problems firing. I'm thinking it's a fuel problem. I run blown alcohol with 10.0 to 1 and sometime have too give i little shot of gas when it's warm.
kwkracing 07-09-2009 08:57 PM
But Zip, he says it has spark, but he is also asking if the coil is bad, so i am assuming he doesnt know if it has spark or not when it gets hot. Lol. I believe its a fuel prob too.
zipper06 07-09-2009 09:00 PM
Yah, you're right, not enough imfo.
bbchevy 07-10-2009 07:19 AM
Spark
Well?
I se He replaced the Mag.Pick-Up in the Dist.So it DONT Have a Mag?It could have Spark with the current more than likely MSD set-up,just NOT Enuff...........?
Put a Super Mag in it and Light the FIRE!'
Later
G 8)
kwkracing 07-10-2009 08:25 AM
No, im sure its a msd and a electronic efi for a street show car? But i guess we will never know?
