-   -   Stall Converter Trans Brake Powerglide and launch rpm (https://www.racingjunk.com/forums/showthread.php?t=24868)
jreiley 07-08-2009 03:47 PM
I'm confused about stall speed, etc. Given the above, what rpm do I want the engine to be at when I launch with or without the transbrake. Thanks.
TheRabbit 07-08-2009 04:26 PM
You want to launch "flash" your convertor 200 rpms over your peak torque on foot or t-brake. This alone is a good reason to put a motor on a dyno.
jreiley 07-09-2009 10:44 AM
I wish I could do that. No dyno's anywhere near me.
dparker 07-09-2009 01:31 PM
Need more engine info then......
jreiley 07-10-2009 04:35 AM
Ok. 509 Dart BBC, 871 Blower - 10lb boost - CompCams blower grind solid roller, Profiler heads, Advanced Transmission powerglide, new converter but I don't know what the stall speed is. I can find out easy enough, I just haven't asked yet. The old one on the non-blown engine was 3800.
TheRabbit 07-10-2009 07:11 AM
Hey guys when he threw the blower in I don't have a clue what to suggest other than they makes tons of low end torque but I'm lost on this one. Get the cam specs and convertor specs I could help a little more.
hammertime 07-10-2009 08:26 AM
Stall speed is not something you would ask anyone its something you would find out one of these ways.
1. Have a playback tach, and when you launch the car takes off and the converter flashes, this point is called the flash stall. Also when you shift from 1-2 and the rpms drop this is called the stall recovery.
2. You can check it by pulling the launch chip and putting it up on the transbrake and see what rpms the converter goes to. This result is not the same as the track will be though.
jreiley 07-10-2009 03:02 PM
I am getting more and more confused. What does a stall converter do that a regular torque converter doesn't? And what is flash?
FullTimeRacing 07-10-2009 04:11 PM
SMASH on the brake,then start giving it gas,watch the tach,when the car tries to move remember that RPM.Then tell us :P
TheRabbit 07-10-2009 05:17 PM
I don't mean to pick or be rude, but I do have a ??. This seams to be a pretty big motor for somebody that doesn't know much about stall convertors. PLEASE don't take that wrong. I'm like everybody else and trying to figure out all the details so we can help. You're just a long ways into this to be asking this question. Again not trying to pick just trying to figure it out.
