78 cordoba steering shaft
how does this shaft come off the steering box? i already took off the bolt.what else do i need to do to get it off?
Ok first of all what part are you replacing? The shaft doesnot slide in and out, you either remove complete steering column,or remove the steering box, depending on what you are replacing :!: :!:
''JUST MY TWO CENT'S WORTH'' http://www.racingjunk.com/profile/163312 |
| All times are GMT -8. The time now is 05:31 PM. |
