700r4 vs 4l80e vs 400th vs big cam
i have a 37 chevy with a 400 small block and need to buy a transmission i need 3500-4000 stall so i was wondering if i should even be looking at overdrive
I am thinking this is a street car, so everything depends on your rear gear ratio.
You have a crusing speed (RPM) and a highway speed (RPM). A loose converter builds a lot of heat if you do not run enough RPM to get over the stall. Dave |
If your running a big gear in the rear a od tranny would help put at highway speed, but if you have a 3.73 or 4.10... i would not be running it in od unless you plan on cruising at 90+ mph on the highway when the convertor is locked at 4g.
I would try getting a friendlier cam, going with od if you are planning on Highway driving. If you just want to play put a 3 speed. |
| All times are GMT -8. The time now is 08:20 PM. |
