-   -   SBC Head choice for 406 (https://www.racingjunk.com/forums/showthread.php?t=24764)
supergass 06-28-2009 05:50 PM
I want to keep a 23 deg head but there are a few good chioces. I have a set of AFR 227 CNC and they are very good. Are there anything out htere new yet any better? I know that Brodix has a head hunter oval head but it doesnt seem to be any better according to the numbers posted. I am building a 406 with 11.5 to 1 and a roller with 700 lift and 260 and 270 at .050. Dart even has a 232cc head and one in the 240cc runner volume. What is working, is the all pro heads worth the money ? I see they have a Raised Runner 245 cc head and a Raised Runner 227cc. Im thinking the pricing they are posting are for 1 head.
jmarksdragster 06-28-2009 07:14 PM
You might check with AFR and see if they can update it, they have a new 235 version.
http://speedtalk.com/forum/viewtopic.php?t=17031
Unless you are class limited I would go to an 18˚ or 15˚ for anything more.
supergass 06-29-2009 01:56 AM
Thanks Mark, that was just the info I was looking for! It appears to me that Big Joe is satisfied with the AFRs. I like the other 18deg and 15 deg stuff alot but I try to remember Im just a bracket racer and to keep myself from going crazy. It helps me to be able to buy fresh tires and race fuel when I need it too!!
jmarksdragster 06-29-2009 06:56 AM
Joe seems to have a knack with making power out of AFR heads, you might even send them to him to update. If you have run yours for a fair amount of time be prepared to get new valves and springs as well.
houtxgent 06-29-2009 05:02 PM
Hea Choice
I amin the middle of getting my parts together for a 408 sbc. I got an Eagle Forged crank,Eagle forged H-beam rods and forged 14-1 Mahle pistons. I have a Comp solid roller cam 673 lift with duration of 262 and [email protected]. My question too deals with head choice. Has anyone had any expierence with Patriot or RHS heads? I have found a couple of dealers where I can get the Patriots with 220 runners and 2.08 and 1.60 valves for around $1100. Basically same thing with the RHS heads.....only 235 runners. I am not trying to be cheap....just not break the bank for now.
fishman1 06-30-2009 08:30 AM
Re: Hea Choice
Read the post above they are telling you the best heads that are out there and there wasn't one mention of patriot or rhs.....if you do a search you will find lots of posts on these heads and none were to postive..........patriot heads are chinese castings and rhs are owned by comp cam a old aussie company if i were to choose i would take the rhs but for the best bang for your buck go to afr
