SHP MAIN BOLTS
Which main bolts do you use with the 4.030 SHP block,Dart or?
Re: SHP MAIN BOLTS
The grade 8 bolts and washers Dart supplies seem to be pretty good. Once the hardware is installed you may want to check the housing bores for size as it amy need an line hone. |
Well Carl I'm still going to purchase block from you,retired and got married so some of my racing projects are taking a more time.Thx for the info
| All times are GMT -8. The time now is 01:12 AM. |
