foxbody wheel qustion?
i have a dead stock 89 lx
i recently purchased some 15x8 draglites to put on the rear and the lug bolts are too short. any body else run into this problem? im just wandering what would be a good length lugbolt to run to have plenty of room for the nuts and washers thanks -nick |
Studs
Jegs & Sumitt both sell longer studs.... At most drag strips if you run under a certin ET you must use longer studs. The NHRA rule book has all this info..
Haddy Daddy 8) |
| All times are GMT -8. The time now is 06:01 AM. |
