TH 400 have you ever delt with the "Governor"
Have you ever had to adjust the weights on your tranny governor to get your miles per hour speeds in a good range compared to gears shifting range for example, my tranny shifts from 1st. to 2nd. gear and going to 3rd, by the time the speedometer reads 36 or 37 MPH. wondering if you have some input on the matter? Thanks for your time in thinking about my problem. :( My vehicle is a 1986 Suburban 2500 with a sbc 350
Since no one has responded to this question, what are you trying to do? get it to shift later or earlier?
In the old days when we wanted to up the shift points on a 400 we used to drill (4) 1/4" hole in the swing weights on the gov. this lightened them up making the shift points higher on acceleration. Of course with todays and yesteryears modified 400's the gov. is eliminated/pluged. Zip. |
The governor is mostly for WOT adjustments. B&M (and others, i am sure) have a kit to let you do this. It is mostly trial and error, but you shouldn't lose any fluid, so easy enough to do. Kit consists of springs and weights.
The part throttle shifts are controlled by the vacumn modulator. You can pick up an adjustable one at most parts stores. Also easy to replace, and adjust. |
If you ever had one stick while slowing down to stop with the tranny in high gear, you'll know. It will start bucking and jerking and carrying on. Cp |
[quote="cepx111"]
If you ever had one stick while slowing down to stop with the tranny in high gear, you'll know. It will start bucking and jerking and carrying on.Cp |
| All times are GMT -8. The time now is 09:28 PM. |
