-   -   dimension difference between big and small block chevy (https://www.racingjunk.com/forums/showthread.php?t=24690)
fsdragster 06-21-2009 06:36 AM
besides the weight of the big block is the overall width or length different between them. car had a small block with front plate and looking to go bigblock. thanks
Tod74 06-21-2009 07:43 AM
They are a lot wider. It is the cylinder heads more so than the block.
Drtmod5 06-21-2009 07:57 AM
They are also @ 3-4" longer in front of motor mounts. I switched mine a couple seasons ago & everything bolts up the same except the front is now closer to the radiator.
fsdragster 06-21-2009 08:47 AM
so the clearance to the firewall is the same its the front that changes. my car came with a small block plate. do i alter that or just buy a new one
hammertime 06-21-2009 08:59 AM
you'll have to buy new
desoto30 06-21-2009 11:12 AM
^^ & move it forward 2"
hammertime 06-21-2009 11:14 AM
x2 they are 2 " longer
desoto30 06-21-2009 11:17 AM
Just thinking, sometimes you are able to cut out the front plate to accomodate the BB. sometimes not depends how the first is made.
fsdragster 06-21-2009 02:58 PM
THANKS FOR ALL THE EXPERT ADVISE. HAPPY FATHERS DAY TO ALL. FRANK
