Header Problems
Any help would really be grateful. I have an 81 Monte Carlo that Im building for the Strip/Street I built a 520 Tall Deck motor. It was not suppose to be for this car I had a full chassie Camaro Drag Car but its gone. So I thought I would find a cheap car and put this motor and my turbo 400 into. So I came across this Monte Carlo got for nothing the body is perfect. I bought a 9" for it and now Im stumped. Can't find a header that will work. Hooker Tech tells me that there 2241 that is for BBC in a G body may or maynot fit. And at 500.00 I was hoping for a better answer than that. What is the solution? Any body run across this problem? Thanks David
for about 14-1500 Lemons will make you a set that wil fit. 4-6 weeks backorder.
http://www.lemonsheaders.com/ They will fit though.... |
buy a kit and weld up your own..or cut apart a set and modify them.
81 Monte/Malibu is a G body hookers should fit, but you may have to run a front motor plate, they did fit my 80 Malibu at one time before i went sm/blk
JMO Zip. |
Look around in your area. I found 3 differnt guys in my area that build headers ranging from 800 to 1000 Coating opional. Good luck
| All times are GMT -8. The time now is 12:16 PM. |
