Sifting on time instead of RPM
I have a BBC super comp dragster with a powerglide. Right now the transmission shifting is being controlled on RPM (7400) by my Biondo Mega 450. I would like to figure what time interval I should enter into the box, for a starting point, to allow the shift into second gear when the box is controlling the shift by time. I am not using the throttle stop at this time.
Re: Sifting on time instead of RPM
FYI its illegal nhra and ihra to shift the car by the mega 450 rpm and have the tach wire hooked to it :shock: |
FYI its illegal nhra and ihra to shift the car by the mega 450 rpm and have the tach wire hooked to it :shock: Thanks, David. I haven't looked at the playback tach yet. I assume it shows time and RPM? When I had the chassis certified the NHRA inspector told me that I had to not only unhook the tach wire from the box but cut the dash enough so the tech inspector would be able to see the tach terminal on the box. I assume this is only for sanctioned events? Does anyone shift their dragster manually? Is it possible without causing damage? |
FYI its illegal nhra and ihra to shift the car by the mega 450 rpm and have the tach wire hooked to it :shock: Thanks, David. I haven't looked at the playback tach yet. I assume it shows time and RPM? When I had the chassis certified the NHRA inspector told me that I had to not only unhook the tach wire from the box but cut the dash enough so the tech inspector would be able to see the tach terminal on the box. I assume this is only for sanctioned events? Does anyone shift their dragster manually? Is it possible without causing damage? You can shift manually but its not consistent, add a rpm switch and be done with it. |
You wouldn't want to be shifting by time would you? If you have any launch problem it may shift too soon.
| All times are GMT -8. The time now is 08:32 PM. |
