-   -   Steering wheel switch and bracket (https://www.racingjunk.com/forums/showthread.php?t=24587)
jreiley 06-12-2009 01:11 PM
This is probably the wrong place to ask, but I want to put the line lock switch and the tranny brake switch on a bracket mounted to the steering wheel. I can't seem to find anybody that makes the bracket. I know I saw it somewhere but, old age prevents me from remembering where. If anybody knows, I would appreciate your help.
TopspeedLowet 06-12-2009 01:23 PM
The bracket I use most often is the spokes that are on the steering wheel itself. I drill a hole in one that lines up with where I like my hand to be and use a double nut to lock it in place. If you have no flat spokes on yours, then a U-bolt holding a piece of aluminum on a spoke with a hole in it for your button may also be an economical choice that you can make to fit your steering wheel better than a generic bracket purchase?
Bruce
oldandtired 06-12-2009 02:16 PM
We are asuming you are driving a door car. Therefore all you need to do is get a somewhat flat steering wheel. If it comes with holes, you are half done!!
Dave
curtisreed 06-12-2009 03:54 PM
Is this what you are looking for?
https://www.appliedracing.net/produc...753482f9c8e1c2
