-   -   Acceptable offset between crank/trans input shaft (https://www.racingjunk.com/forums/showthread.php?t=24583)
kicker91laser 06-11-2009 07:28 PM
With all of the adapter bellhousings and plates, it seems that the crank and input shaft on the trans may not be perfectly centered with each other. That being said, what is an acceptable amount of offset between the two? If it matters, this would apply to th350/400 trans.
zipper06 06-11-2009 08:39 PM
I don't know what the acceptable amount is but i can guarentee you if you have as much as .005 you will have a front seal leak very quickly after the trans is installed.
kicker91laser 06-12-2009 12:19 PM
Thanks zip, is it an acceptable practice to use offset dowel pins with the auto trans?
TopspeedLowet 06-12-2009 01:03 PM
The dowels are to compensate for an ALIGN BORE job on the mains that moves the crank up toward the camshaft. No offset is "normal" any thing else is off.
Bruce
chevyfireball 06-17-2009 04:40 AM
Wouldn't even go there bud. You're asking for trouble.
