Rons 1/2 pump and alternator
I remember reading a post someone had about mounting brackets for a rons pump, alternator, and vacuum pump but I can't find it. I've got a BBC in a dragster and will be using all three if I can find a link to the website that sells them. Any help wound be appreciated.
Thanks James |
Hey David, do you still have those pics of how yours is mounted. I did mine just like that and if worked great for me. James traded his roadster for a Danny Nelson dragster. I guess you can say I came over to the Dark Side.........
James shoot me your email and I'll send ya some pics |
sent pics hope it helps I am sure I have more somewhere or could shoot ya a few more.
Mine is rons 0 1/2 pump with crank trigger under it on bottom left, moroso vacuum pump mine is on top right of motor but wouldnt matter which side you mount it actually easier on left but my valve covers were drilled backwards of this, just a normal moroso vacuum pump mount. 100amp east coast alt, with east coast alt mount on bottom right. Not really even a tight fit. |
Thanks for the pics David, I have plenty of room but I couldn't get the layout to make since. Now I see what I have to do. Thanks again.
| All times are GMT -8. The time now is 08:05 AM. |
