-   -   SBC Engine Block Identification (https://www.racingjunk.com/forums/showthread.php?t=24513)
dgordner 06-07-2009 03:26 AM
The numbers T0520HV are stamped on the tab in front of the right side head. I am of the understanding that it is a 1965 327/350 4 bolt. When I pulled the pan, it was a 2 bolt. Any help?
oldandtired 06-07-2009 11:24 AM
What is the 7 digit numeric code on the back of the block? If you have a 65 327 it should start with 37, 38 or 39.
Dave
dgordner 06-07-2009 03:22 PM
3956618
fla1976 06-07-2009 03:46 PM
Engine
According to my books, it decodes as a 1965 Corvette Special high performance, transistorized ignition. It should be a 4 bolt but maybe somebody doctored the numbers at some time.
fla1976 06-07-2009 04:08 PM
3956618
The casting number decodes:
Years Casting CID Low Power High Power Main Caps Comments
1969 3956618 302 290 290 4 Z28
1969 3956618 327 235 235 2 fullsize
1969 3956618 350 250 350 2/4 cars
Here is the site: http://www.nastyz28.com/sbchevy/sblock.php
dgordner 06-07-2009 04:55 PM
I am having a hard time understanding why the numbers on the block up front tell me one thing and the numbers at the back of the block are telling me something else.
oldandtired 06-08-2009 05:30 AM
On the front, you have the possiblity of a restamp. You can't mess with the casting numbers.
Dave
hotrodharley 06-08-2009 06:54 AM
go to this link..very good id's on casting no#'s
http://www.mortec.com/bbc.htm
sure this will get you in right way of reading casting no's on blocks/cranks/everything
dgordner 06-10-2009 03:39 AM
So if the casting number tells me that it could be any one of different c.i., How would I determine of it is a 327-350 ?
fla1976 06-10-2009 12:17 PM
Engine
1.Get the number off the crankshaft and find the code.
2.Measure the stroke
