towing
does anyone know if a 44 or 48ft g/n will be to much for a 3/4 ton pickup to tow safely?a friend has a 3/4 diesel that he looking to purchase a big trailer but i don't think there is enough trauck.does anyone have another opinion on this subject?
I have a 48' Halmark with living quaters and slide out goose neck. Loaded it's 5100 lbs. on the truck
I TOW A 9000 LB TRAILER WITH SILVERADO 2500 HD WITH 6.0 . I HAVE NO PROBLEMS.
I tow 18,000 with a C4500 Kodiak. No problems. Had a 95 C3500 with the 6.5, it didn't like towing anything.
You also probably need to look at the truck wheelbase. The longer the better. I probably wouldnt' do it with a short w/b truck. |
It will work but wont be ideal
Trailer
I have a 3500 GMC 1998 HD 4-Dr.Dually,4x4.And the Trailer is a 2003 Pace 45' that weigh's in @ 9400 MT,and we usually Gross around 15,Grand.
The Truck has a 7.4.4L 80-E.Pulls the Load and Stops with NO Problems! I had a 1992 GMC Toter,8'Box plus the 6' bed.It was Nicew as far as the Electric BRAKES,but the 366 Gasser>?Would NOT pull a NASTY WHORE OFF THE STINKPOT! The P/Up is MORE Versitale!!! Hope this HELPS. Later G 8) |
| All times are GMT -8. The time now is 04:19 AM. |
