PLUG GAP on blown sbc ??? please help
Hi, thanks in advance for the help!! I have a 414 sbc 8-71 dbs blower and enderly mechanical fuel injection. base engine is 9.2 compression, blower 10% underdriven, running f&l sp-1 or sp-3 fuel, same as vp c12 c14. Ignition box is a 7-al3 not digital. My question is what should I run the NGK v-power #8 sparkplug gap at? I was told between .025 and .030..... is this close?? Reason I'm asking is, at the top end of the track I have what feels like a random misfire, engine has plenty of fuel -- went 20 #'s fatter on the pill, Have taken 8 degrees of timing out of it and still the same. Please point me in the right direction if you are familiar with this set up, THANKS!!!
I run around .040-045. on my blown sbc on gas or alky. what is the timing set at? Why are you not burning alky?
on my blown alcohol sbc motor I run 25 thou on the plug gap with a 7 al3 , any wider and I have miss fire at high rpm , thats just what my set up likes,,,,Paul :D
You can and have tried larger but I will say .018-.025.
Might check your pop off plate if you have coughed it previously. Dave Koehler http://www.koehlerinjection.com |
miss
You NEED to Ditch the MSD Box and get a GOOD Mallory Mag,Super Mag 3 0r 4 and you will be GOOD to go!!!
Just talked to a freind in Indiana this Week same Problem,He Tryed the MSD Route?Took it out and went with a S/M 5 and its GREAT Now! Later G 8) |
MSD works fine on blown carb or injected sbc and bbc's
.018 TO .020
Ok it is learning time for me and I'm loving every minute of it. 434 sbc gas 15.33 to 1 compression and NGK #8's is 35 gap on the plugs ok or should it be tighter.
Thanks Andy |
| All times are GMT -8. The time now is 03:04 PM. |
