-   -   Realigning spider gears (https://www.racingjunk.com/forums/showthread.php?t=24467)
durf 06-03-2009 04:22 PM
How do I realign the spider gears in an 8.5 in. gm 10 bolt posi. I inadvertantly rolled the differential when taking out the c clips to replace the axles and the spider gears rolled down, not out though. I had hoped when I put the new axles in I could roll it the other way and they'd go back:shock: NOT. Any positive info would be greatly appreciated.
Thanks,
Durf
oldandtired 06-04-2009 04:33 AM
If they did not rotate all the way out, they should roll back into place. I believe this rear end has cupped washers between the spider gear and the housing. One or both of these washers may be the binding problem.
Good Luck, Dave
durf 06-04-2009 01:25 PM
Yes it does have the cupped washers, thanks I'll try that.
