need help fast
hey my fuel pump died on my 92 chevy 1500 and need help
i know its dead cause i disconnected my fuel line and tried to start it but no fuel came out of the line easiest way is to take off bed? or drop tank? other question can i take the fuel pump out of my 93 chevy 3500 and put it in my truck or will a holley work need help uick please |
might not be the pump,,,some cars have an oil pressure switch that activates the pump circuit , not sure if your model does or not , but some do , check to see if you are getting fire to pump before going to alot of trouble....J M O , :D PAUL
drop the tank, the pump for that truck is cheap, I would just buy new. about $45.
A quick check (works about 90% of the time). As you crank the engine have someone hit the bottom of the tank with a rubber mallet. If it starts then it the pump for sure. If not, could be the relay. JMO
TS1955 |
I just put one in my Dually in August of 2008(2000 chevrolet crew cab ) and it was like $175-200 bucks ....can't remember. I dropped the tank ..it had almost a half tank and I did it alone in a driveway...they never break down at home in the garage. :?
I hear that pulling the bed is easier. I know on a S-10 it is.
Buy a GM pump its worth the extra $$ Autozone or checker pump you'll be doing this again in year. Also change your gas filter and sock filter attached to the pump.
well thamks to all who helped itook the pump out of my 3500 it only had about 5 thousand miles on it put it in my truck and now its drivin like mnormal i left the bed off cause im lazy hah but its helped with gas milag and speed lol that extra couple hundred pounds is nice to have off there but its a lil hard to haul thins now but thanks again
You better watch not having the bed on the truck, if the rear tires sling up a rock it might bust your back window. Seen that happen alot.
| All times are GMT -8. The time now is 10:23 PM. |
