please help me quick can I run this cam
I just got a new 302 for my stang and it has a stock cam in it can I run my trick flow stage 1 cam lift @.50 499/510 I have my old engine works pushrods and roller lifters and dogbone set can I run this set up on the stock lifters thanks for the help if your a ford guru call me at 918-304-9754 thanks jessie
im a real rookie at this and espacially with fords but i would think you would need an upgraded fuel system carb pump etc but like i said im new so you might wana ask tod or mopar or maniac there extreemely seasoned racers
my set up right now is holley mech. fuel pump, rpm intake manifold, holey carb,bbk equal shorties full msd ignition, brand new motor
o ok well i dont see a problem with it but like i said im new i just dont wana give you advice thats not worth a sh*t
http://www.racingjunk.com/profile/22735
this is maniac idk his realname but from what ive read in prior posts and what not he knows wat hes talkin about |
well the only thing I really want to know is if I can run my stock rocker arms with a roller cam, or do I have to buy roller rockers, any one out there have a set of 1:5 or 1:6 roller rockers that will bolt to a set of stock 302 heads thanks jessie
if they are solid lifters i don't think so, at any rate, give crc automotive racing engines a call, ask for ron. 937-743-9826.
| All times are GMT -8. The time now is 12:32 AM. |
