-   -   Holley 80532-1 metering block gasket (https://www.racingjunk.com/forums/showthread.php?t=24357)
swany388 05-23-2009 05:47 AM
Could some tell me which metering block gaskets I need for a Holley 80532-1. I went to Holleys wed site and the specs for the carb list a 108-108 gasket. I can't find this gasket on a web search. Is there a different number that works. Thanks Steve
jmarksdragster 05-25-2009 02:35 PM
Your 80532 would be a 1250 Dominator. I also happen to have one I converted to a 2 circuit carb. The gasket you need is the same for most 3 circuit Dominators, any speed shop should have one. If you have to order any Holley parts you can get everything you might need here.
www.blp.com
800-624-1358
Ask for Joe, Mark, or Robbie on the counter.
