perplexing problem
brand new AED 4150 carb
set floats and pump shot initially I had a bog from standing start. changed cams and shooters (BIGGER) second road test: stomped the throttle and spun tires through first into second. :D next day warm car up to temp as before. step on gas and bog is back??????? took off pump arms and bent the arms a little. readujted accel pump for .015 at WOT. ok back to smoking tires! next day same ol bog again? this got me scratchin my head????? maybe bigger accel pumps ???? |
You can go up to a 50cc pump on the primaries, but you've probably got another issue, are you sure your getting adequet fuel pressure?
yes 6.5 psi at idle
5.5 psi at wide open |
Originally Posted by rabiddawg
yes 6.5 psi at idle
max for a holley is 7 PSI |
Lean problem. In the morning air is better bog. Later in the day air is worse no bog. Turn your idle screws out 1/2 turn. May need 50cc pump and/or little bit bigger squirters.
hmm plugs are a dark tan and color change is at bend of the ground strap.
I do get some cutting up ( or muffled popping)on decel but didnt notice any pingng or detonation. running leaded 110 sunoco gas ill try going up 2 jet sizes and see what happenes |
I would call AED and ask them...would have thought the thing was closer than that out of the box...as far as the pump cams and squirters I mean.
i woud put a 50cc pump on for sure, if you have another gauge, i would swap the old one out, i have seen gauges that were off as much 1.5 lbs, i would also try a little more pressure, good luck.
| All times are GMT -8. The time now is 08:32 PM. |
