Q-16 and NOS
Anyone have any experiance with this or is it not even worth messing with?
you'd be suprised how much you can spray on Q16! its a bad beeotch
Vp makes a new fuel they call NO2, designed for nitrous, it is amazing stuff, we use it in our pro mod car running 4 stages
i wouldnt consider N02 new? Its been around for a long time now.
Yes, n02 is the fuel to go with if spraying a lot. But for 300hp or less of the silly stuff Q should be perfect. |
So do you have to put a bigger fuel jet in the nos system to compensate for the extra oxygen? We had to go 8 jet sizes up in the carb to compensate for it so l assume l would have to do the same with the fuel jet in my fogger?? |
Also heard this stuff has to be kept sealed up and not to get it on you, is this stuff really that much of a pain that you have to drain it out of your fuel cell all the time and keep it sealed up?
The main reason they would like to see you drain, is because when you are tuneing your car for the extra oxygen....then allow the car to just sit. The oxygen will exscape (in a way) and then your tuneup will be running rich. Throw new fuel back in, and it's spot on. That is why they rec. that you do only if the car sits a long time. |
| All times are GMT -8. The time now is 05:27 PM. |
