BROKEN GLIDE
Today I left the line,car shifted into high then acted like it went into neutral and motor hit the hi side chip.I went to pull out of the groove and then the car started to lock the rear tires,then just coasted.I have no low,high or reverse,just park.Did it break the planetary?Stock 1.76 with a couple thousand runs,but trans just rebuilt 170 runs ago.Any idea on what broke?
If the planetaries broke you wouldn't have Park either...
At least that is what mine did when they broke. |
I just removed pan and it is clean and so is the filter.Nothing unusual in pan,so is it convertor or??
PG
You may have broken the front pump. It's easy to check, just pull it out and check the gears. I broke one and it felt like you put it in neutral. Relatively easy fix.
Check the input shaft, it's probably broken
what dose the car run and how heavy?
I serious doubt the planetary broke causing the input to break. The input shaft just could not handle your weight and power.
I busted an input shaft doing a burnout. Shit happens. Get a bigger shaft.
| All times are GMT -8. The time now is 05:53 AM. |
