-   -   I'm new.. Let me try this... (https://www.racingjunk.com/forums/showthread.php?t=24286)
prestonoodle 05-17-2009 07:47 PM
I hope this is the right spot for this....I took my 66 stang to the track for the first time. Its got a 289 w/ .030 over forged pistons, stock rods, stock crank, crane 292 dur./512 lift, 1.6 roller rockers, canfield 2.02 heads, RPM intake, eldelbrock 600 carb, hedman long tubes, 4 speed, stock 8" (I know) w/ 4.10's and a mini spool on street tires(I going to get some slicks soon) . I don't know how heavy the car is. I was shifting at 6k and went thru the traps in 4th at 5500. Think I could hit the 12's with slicks? tell me what you think. Thanks Kelly
1st pass Spun 2nd real bad, let off got back on it.
R/T .352
60' 2.040
330' 5.879
1/8 9.022
mph 79.72
1000 11.668
1/4 13.902
mph 101.20
2nd pass Tried small burnout, Still spun 2nd but not as bad
R/T .177
60' 2.166
330 5.873
1/8 8.873
mph 82.60
1000 11.445
1/4 13.625
mph 103.47
Final pass Same as 2nd pass
R/T .147
60' 2.067
330 5.793
1/8 8.818
mph 81.95
1000 11.416
1/4 13.617
mph 102.58
justin45 05-17-2009 07:52 PM
i think a high to mid 12 is very possible but put a 750cfm carb on there cuz i bet ur motors being held back from that 600cfm
THERATTLER 05-17-2009 07:52 PM
:D CAR LOOKS TO RUN PRETTY GOOD FOR WHAT IT IS , BUT THE REACTION TIMES STINK , PROBALLY WOULD STILL BEAT A MOPAR :shock:
kbartley 05-17-2009 08:51 PM
I'M NEW
How hard are you leaving and what kind of street tires? Slicks will find the week link. I agree a 750double pumper will help it breath and definitely run faster & quicker but it will also shake the tires loose when you open it all the way(mechanical secondaries). You need both, just don't go w/ too wide of a tire. I had a 74 Nova SS 4-Speed car 400 smallblk. shortrod, dish piston, doublehump's, muncie, 4.10 10bolt back in the 1990's that ran mid 7.80's. Goodyear 10"slick, thats all I could get at the time. Was leaving at 3500rpm & either smoke the clutch or bust a u-joint. Pop told me "LEAVE HARDER", play w/ the tire press., that did the trick. Keep up posted, ask ?'s. Kris
mopar1968 05-17-2009 08:56 PM
I think you might hit 12's - Yeah maybe a neon :!: :!: :!:
''JUST MY TWO CENT'S WORTH''
http://www.racingjunk.com/profile/163312
dparker 05-18-2009 11:22 AM
Re: I'm new.. Let me try this...
R/T .352
60' 2.040
330' 5.879
1/8 9.022
mph 79.72
1000 11.668
1/4 13.902
mph 101.20
R/T .177
60' 2.166
330 5.873
1/8 8.873
mph 82.60
1000 11.445
1/4 13.625
mph 103.47
R/T .147
60' 2.067
330 5.793
1/8 8.818
mph 81.95
1000 11.416
1/4 13.617
mph 102.58
I you'll look at your last 300' you can see you were slowing down eventhough you were quicker in all the segments in the first 1/8. Your carb is running out of pop, and will probably only get worse as you get quicker. Get a 650 or 750 double pumper Holley carb, it will put you in the 12's.
prestonoodle 05-18-2009 12:32 PM
Thanks for all the tips. I do have a 650 DP that i'm going to try. The tires are 255/55/17 nitto's, plain radials, no D/R's. I going to get some M/T 28/9/15 slicks soon (if I find used even sooner) 10's are to wide to fit in my wheelwell. My reation times do suck but hey, I haven't been to the track in like 12-15 years, give me a little seat time i'll be OK :wink:
Here she is waiting for some body and paint work :P , Oh and I am the 2nd owner, the first was my father, he bought it new in '66.
http://i268.photobucket.com/albums/j...ictures024.jpg
http://i268.photobucket.com/albums/j.../engine005.jpg
THERATTLER 05-18-2009 02:42 PM
:D hey,,,thats a nice little stang :D :D
lively 05-18-2009 06:39 PM
VERY RESPECTABLE :lol: :lol: :lol: :lol:
justin45 05-18-2009 07:54 PM
thats a purty sweet lil stang
