-   -   starting prob (https://www.racingjunk.com/forums/showthread.php?t=24282)
Strick420 05-17-2009 01:52 PM
starting prob
hey guys I got a 89 mustang gt, with a problem the car will start and run but when I turn it off it won't start back up. could it be a power or a heat problem any help would be great thanks guys
cepx111 05-17-2009 05:27 PM
wont turn over? turns over but wont start? please explain in detail your starting problem
Cp
Strick420 05-20-2009 07:42 AM
it won't turn over after running and if i try to start it, it sounds like the battery is dead if I let it sit for a couple hours it will crank up and run fine any ideas
ARUSSELL 05-20-2009 07:43 AM
Get a better ground
txhunter69 05-20-2009 08:02 AM
check your battery terminals if there lose it wont give the motor enough power to start this happened on mine and my brothers truck had to clamp the positive terminal with vise grips to get to the parts store
FullTimeRacing 05-20-2009 08:03 AM
Or the starter is bad
txhunter69 05-20-2009 08:04 AM
if the starter was bad it wouldnt turn over
FullTimeRacing 05-20-2009 08:08 AM
he says it won't turn over :oops: :oops:
txhunter69 05-20-2009 08:09 AM
o haha thanks for pointin that out im feelin real smart :oops: :oops: :oops:
FullTimeRacing 05-20-2009 08:10 AM
starters tend to drag when hot and old,may start find when cold but not hot
