starting prob
hey guys I got a 89 mustang gt, with a problem the car will start and run but when I turn it off it won't start back up. could it be a power or a heat problem any help would be great thanks guys
If you have added headers there is likely a heat problem with one of the primaries coming too close to the starter without heat shielding. If you do not have headers then the stock heat shield may be missing if it is a heat problem. You could also have a tired starter that is heat challenged. I have used paint thinner cans cut into sheets to wrap around exhaust pipes that come close to the starter to provide rust free heat shielding. I tie them to the exhaust with monel wire or stainless .063 tig wire. These are the most common heat problems involving the starter. If you have too high a timing setting, then the engine will roll over much harder when hot and cause a nearly no crank condition. A flooded engine will hydraulic if too much fuel is in the cylinder at restart if for instance the power valve is blown and filling the engine after shutdown. Leaking injectors can contribute to hard cranking if you do not have a carb. Do any of these causes fit your problem?
Bruce |
start prob
well if tat ont fix it try checking the crank sencer it coud e craked or the ir ap gets to ide fom the vibrtion of the moter
Re: start prob
Re: start prob
As DrivingMissDD would say, press one for english :) |
Re: start prob
As DrivingMissDD would say, press one for english :) Either way, good luck!! Scooter |
Re: start prob
As DrivingMissDD would say, press one for english :) Dave |
Well-I'll-be-dipped! I didn't catch that. :)
Wrong. 11211980 is the day he graduated from Harvard. Just kiding, I never made it that far either..
His post sounded like the old guy from the movie Water Boy!! LOL |
You mean Billy Bouchea`??? Dat Fool can play sum futball dough.
| All times are GMT -8. The time now is 04:18 AM. |
