HP Guess
This is the engine i'm running in my 89 1/2 ton two wheel drive this summer i'd like to get some guesses on HP before it hits the dyno next week. The truck is in getting a three link installed along with a 9" ford rear should be done next week.
358ci Scat 4340 43lbs crank eagle 6" H beam rods JE 12.1 to 1 pistons Reed solid roller 262/267 @50 618/625 lift 106 split Brodix alum 11x heads fully ported polished,bench flowed should be approx 240cc on intake side i don't have flow sheet yet jessel ss rocker system 1.5 ratio Mass flow fuel injection with 45lb injectors My guess a solid 550HP |
I think you are pretty close...1.5 hp per cube is 537
HP
I'd guess around 550.
I would say a Briggs & stratton has more :!: :!:
''JUST MY TWO CENT'S WORTH'' http://www.racingjunk.com/profile/163312 |
MOPAR must have lost to a Chevy recently..... :lol:
Nah thier not quick enough, get up to the light's and still have to give at least 2 lights, then feather the throttle so when i pass them it doesn't look so bad on them at the end.
OH BROTHER ITS GETTING DEEP AROUND HERE, TIME TO PUT ON THE HIP BOOTS :!: :lol: :lol: :lol:
Mopar 1968
Just wondering are you going to have to kiss up on Obama to by parts for that Mopar from GOVERNMENT MOTORS?
Nope i work at a dealership so i can get all the MOPAR parts i want, check my profile, and the parts doesn't cost me a penny :!: :!: I don't kiss anyone's a$$ for anything :!: :!: Now see that's is what i don't understand about idiots like you, you really don't understand what is going on with the auto industry but you come on here with 3 post under your belt and start calling it goverment motor's, Please the next time you start to shoot off your mouth about something you have no idea about, DON'T :!: :!: And by the way GM is in alot worse shape them chrysler is, chrysler closed 700 dealerships, GM is closing close to 1200 :!: :!: enough said :!: :!:
Relax
Mopar1968: I would have thought you had a sense of humor when you posted ( I would say a Briggs & Stratton has more ) as i took it in good humor. When i made my comment it was meant in good humor but you appear to lack the maturity to recognize it for what it was. As for you having 912 post and myself only 3 it only took to reading the third post from you to realize that i won't bother to read another. Go ahead and rant i won't waste my time as i see your opinions as irrellavent.
| All times are GMT -8. The time now is 05:07 AM. |
