engine pops back thru the exhaust
460 ford installed new cam lifters and springs(hydraulic) new wiand plugs< what can it be
More info, when does it do this, street car, race car :?: :?:
''JUST MY TWO CENT'S WORTH'' http://www.racingjunk.com/profile/163312 |
race car, mostly at idle
Valve staying open or closed.....
Sounds like ya have a valve or two too tight to me! JMO
TS1955 |
Sometimes it takes a little while for the lifters to pump up. Make sure you recheck the lash after you run the engine a little while. If there pumped up you should have oil coming off all the rockers.
Yeah i would have to agree, back the lash off a bit and see what happens :!: :!:
maybe u didnt degree ur cam right????
Your popping through the exhaust because the vavle lash is too tight on the exhaust valves or lobes going flat on the camshaft.
| All times are GMT -8. The time now is 11:37 AM. |
