-   -   titanium vs. stainless (https://www.racingjunk.com/forums/showthread.php?t=24216)
vegabond 05-12-2009 03:23 AM
What is the advantage of titanium over a stainless valve? My motor is 377 sbc with 18* gm heads. It needs freshened and i dont know if i want to spend the money for new tit. valves,it's just a bracket motor. what would i lose E.T. wise? Horsepower wise?
TS1955 05-12-2009 03:30 AM
I'm not an expert on this, but I've been told if you are not going to run your engine over 7000 rpms don't waste your money on titanium. I do know they make your valve springs live longer.
TS1955
vegabond 05-12-2009 03:43 AM
I do spin it preety high about 8,000 to 8,200 thur the lights.
TS1955 05-12-2009 03:49 AM
If the funds are there, then you probably should consider titanium. JMO
TS1955
bryanm 05-12-2009 06:40 AM
I have also heard of guys running hollw stemmed stainless valves as a replacement for titanium to help keep the weight down. I think I am going to try them on my new motor.
tcarda 05-12-2009 06:54 AM
From what I understand it is a weight issue on high rpm engines. On my BBC I have titanium 2.400 intakes and stainless 1.84 exhaust and the stainless exhaust valve is heavier than the titanium intake valve. I also run mine between 8000-8200 rpm.
CamBirdRacing 05-12-2009 09:11 AM
Why turn your bracket motor that high anyway?
oldandtired 05-12-2009 11:28 AM
Weight combined with strength. It's another level you can buy into.
Of course I will mention the obvious - run smaller stem (titanium) valves, with titanium retainers, a rev kit and smaller OD pushrods.
This is the diet package for dependibility and high RPM's.
Dave
Tod74 05-12-2009 11:59 AM
Dave
I respectfully disagree about the pushrods.
I don't care if I give up some weight... big pushrods help more than they could hurt...and the weight of the pushrod isn't really a factor since it isn't controlled by the spring...not directly.
curtisreed 05-12-2009 12:42 PM
Dave
X2 with Tod. Sometimes there is good weight.
Curtis
