-   -   electric shift or air which is more reliable (https://www.racingjunk.com/forums/showthread.php?t=24132)
mojomal 05-03-2009 03:51 PM
It time for me to switch to a auto shift in your opinion which one is more reliable?
kbartley 05-04-2009 02:58 AM
electric or air shift
I see at our local track that alot af guys are using electric shifter's. I amssuming its more dependable. When I had my Altered I was going to go to an electric shift so I could keep both hands on the wheel. So I bought a used shiftnoid and msd controller from a guy on this site, but never did use it & of coarse I can't use it on my FED. , not permitted. Kris
I972Nova 05-04-2009 09:26 AM
I have electric in my truck that I installed and air in my dragster (it came with it) I like the electric better, due to not needing an air bottle.
dparker 05-04-2009 12:16 PM
I think the air might be alittle more acurate, but it sure nice is not having to worry about turning the bottle off and do I have enough air to last the race. I run air but I went over my whole system with a bottle of soapy water to make sure I didn't have any leaks. Your bottle will last so much longer that way. I can also fill my own bottles. All you need is access to a coke CO2 bottle. Freeze your bottle and fill. If I don't freeze I can only get about 8ozs of liquid instead of 10ozs.
TS1955 05-04-2009 06:15 PM
x2 on not having to worry about turning off or filling the bottle. My car has an electric shift and so far so good. JMO
TS1955
BEAST477 05-04-2009 06:37 PM
Are all you guys with electric running glides? I've heard some guys having problems with electric on three speeds. The 1-2 shift is usually good but the 2-3 is inconsistant. Does that sound right?
mojomal 05-04-2009 06:56 PM
I should have said that this is a 3sp auto it seems that might make a difference. it looks like I was leaning towards electric until the last post, so is there a problem with the 2-3 shift using electric?
chevyfireball 06-05-2009 05:42 AM
I use an electric shift on my glide, wired to the MSD Digital 7. It shifts at 7600rpm perfectly every time.
I have no idea how you'd use one on a three stage.
itsabird 06-05-2009 06:07 AM
i use electric with a glide, also heard guy,s have prob with 2 to 3 with them.
THERATTLER 06-05-2009 06:07 AM
I have an electric shift valve body in my glide , shifter stays in low and doesn't move , an electric solenoid in valve body moves valve to high gear , runs off a chip on my MSD 7 al3. works perfect everytime . :D
