lucas ring renewer
yall think that lucas ring renewal stuff works (rings are gettin worn lookin for the cheap way out haha)
That stuff doesn't work. Just a waste of money.
THERE IS A PRODUCT MADE BY SEAFOAM IF I REMEMBER RITE CALLED TUNE UP. IT SMELLS LIKE PB PENATRATING OIL, THAT YOU SHOOT INTO ENGINE THROUGH PLUGS AND TURN ENGINE OVER THEN LET IT SIT, HELPS FREE STUCK RINGS. WE USED IT ON 2 STROKE BOAT ENGINE, IT IMPROVED COMPRESSION TEST RESULTS TO WITHIN SPEC. DOES NOT UNDO RING WEAR JUST FREES RINGS STUCK BY CARBON AND VARNISH
ok so theres nothing that can realy help with my ring wear cause ive burned a quart of oil in three weeks it just started
yea
if ur behind his truck while hes drivin it it smells like nothin but burnt oil comin from the exhause no white smoke to suggest a blown ring but it sure seems like the rings are lettin oil int the combustion chamber |
what are you doing behind him?? if his rings are worn out you should be able to stay in front :lol:
not if your in a mopar :P :P
:lol: :lol: :lol: |
New Rings |
One reason the newer fuel injected vechiles last longer is that with a computer and stock fuel injection parts your engine is getting the optimum fuel mix. Thats why a fuel injected engines last so much longer than a carburated engine. In saying that, thats why when you go changing chips, sensors, intakes, mass air flow, cams, fuel pumps and etc. You are probably shorting the life of the engine. |
| All times are GMT -8. The time now is 05:32 PM. |
