-   -   Upper Door & Window Latches (https://www.racingjunk.com/forums/showthread.php?t=24104)
triniemi 05-01-2009 12:53 AM
Where can I find part like this with reasonable price?
http://www.jerrybickel.com/body-moun...w-latches.html
Does Summit sell them? Couldn't find them on their website.
suicidebomb 05-01-2009 04:31 AM
Might try an aircraft salvage yard. They have lots of neat......stuff.
oldandtired 05-01-2009 07:32 AM
Price stuff from Quarter Max and S&W.
Dave
TS1955 05-05-2009 05:46 PM
Ya have to remember "Racin' ain't cheap". LOL!
TS1955
triniemi 05-07-2009 10:15 PM
We did them ourshelf. Simple butterfly nut outside and J-shaped bar inside the car. Cost less than 10$ and took about 2 hours. So that's (200-10)/2 = 95$ an hour, not bad.
Racefab57 05-29-2009 02:52 PM
Thats cheap those used to be $250 a set.DR.
TopspeedLowet 05-30-2009 02:45 AM
Doo Dadds and stuff
I have never used them yet on any of my cars. I don't feel that they are necessary unless you are sideways at speed with one door blown off the car.
The way I address the issue is I make a gull wing addition at the A pillar that prevents the air from burrowing under the leading edge of the door and keeps it closed with wind pressure blowing over it. The part you are asking about is used on cars that have smooth A pillars that the door closes to without the small spoiler / gull wing that I use and that every one use to use back in the day if you will. My Beretta has this set up with the gull wing and only needs to be about a one inch mini spoiler welded to the a pillar to keep the door safe from air tearing it off at speed.
Food for thought.
Bruce
gmare588 05-30-2009 04:05 PM
hi, i bought my latches from the chassis shop.i can not rember the price but it was cheaper than bickel.hope this helps. garym
