-   -   Help have no Clutch Spring (https://www.racingjunk.com/forums/showthread.php?t=24077)
jjam 04-29-2009 05:06 PM
I have a 1st gen camaro w/4-sp and I got under the car and it had no clutch spring?? is it put on the clutch fork or the shaft. Thanks
oldandtired 04-30-2009 09:39 AM
Between the clutch fork and the Z bar there is an adjustible pushrod. You should have spring that pulls these pieces together, insuring this rod does not "drop" out. I have also seen people add one to the Z bar (or under the dash on the clutch petal) to assist the petal in moving quickly to the upward position.
Dave
