-   -   ENGINE OIL PRESSURE (https://www.racingjunk.com/forums/showthread.php?t=24049)
beerbelly 04-28-2009 09:08 AM
ENGINE OIL PRESSURE
ANYBODY GIVE ME ANY HINTS ON WHY I'M DROPPING ABOUT 30 LBS OF OIL PRESSURE AT 5200 RPMS IN A DRAG BOAT WITH BRAND NEW 454. COULD IT BE RUNNING OUT OF OIL AT THE PUMP OR IS IT SOMETHING MAJOR ANYBODY?
BEAST477 04-28-2009 09:26 AM
I hope you're not using a Fram oil filter.
beerbelly 04-28-2009 09:49 AM
no fram
nope using a wix racing filter
TS1955 04-28-2009 10:05 AM
Just a thought...Does this engine have a "stock" oil pan & a high volume pump? I've seen this happen before. A high volume pump can suck a 4 qt pan dry. Just something to look in to. JMO
TS1955
bowhay 04-28-2009 06:43 PM
i have a high volume in a stock pan and it works fine
but its a 5 quart, it also holds closer to 6 though at the ful mark
what size is ur pan
dparker 04-28-2009 08:38 PM
Re: ENGINE OIL PRESSURE
Have you plugged the bypass above the oil filter. I've seen them open to bypass and pressure drop. The first thing I would do would be to cut open your oil filter and look for any metal. Nip that in the but first.
topsportsman1 04-29-2009 07:17 AM
Sounds like the spur gear pump (Oil pump) is cavatating
