BBC tuning question?
A friend of mine has a bbc in a jet boat the engine idles fine but as soon as you bring it of idle it starts popping through the exhaust. I tried moving the distributer to the left and it got worse so I tried to the right = worse. I'm wondering if its in the carb its a marine style holley p/n R84018-2 Any suggestions would be helpfull. Thanks
im thinking rounded lobe on cam.
Broken or weak valve spring(s).
TS1955 |
running lean???
Re: BBC tuning question?
I'd pull the valve covers and do a looky loo.
He's probably got a broken valve spring, broken rocker arm or pushrod not on the rocker arm, been there done that, I hate that sound. |
I've seen it too many times on BBC marine engines. Dave |
took the valve covers off found a broken spring . I appreciate the help. sorry I'm such a amature :oops:
Don't be sorry. Everybody has to start somewhere. The easiest way to learn is ask ???
| All times are GMT -8. The time now is 04:07 AM. |
