-   -   BBC open chamber and closed chamber confusion (https://www.racingjunk.com/forums/showthread.php?t=24024)
fatjodycat 04-27-2009 06:23 AM
Can you run open chamber heads on a motor that has closed chamber heads on it? I notice that ads for BBC heads never state whether they are open or closed chamber. I also looked at pistons in the Doug Herbert catalog and they have open chamber, closed chamber, and then saw open/closed chamber. Would a motor with GM closed chamber heads accept lets say the GM "990" open chamber heads? Thanks in advance. Eddie
ARUSSELL 04-27-2009 10:23 AM
You can put a set of open chamber heads on a closed engine and have no issues other then less compression.
fatjodycat 04-27-2009 03:12 PM
Thanks.
oldandtired 04-28-2009 02:47 AM
The closed chamber heads have valve shrouding problems, effecting their flow. It's just a design thing. If you run closed chamber pistons with closed chamber heads, at least the dome assist in the breathing.
Dave
fatjodycat 04-28-2009 05:00 AM
Thanks Dave. That gives me more ammo for when I decide what to do for some more hp. I have a .30 427 with oval port closed chamber on it. It is a strong motor but I know there's more potential in it. Eddie
