-   -   copper head gaskets (https://www.racingjunk.com/forums/showthread.php?t=24013)
cobradave 04-25-2009 09:10 PM
copper head gaskets
I have a sbf and want to no how to put copper head gaskets on and keep them from leaking! I have been told to use hyolmar spray can some one help me. Puting motor back together for nmca at bowling green this week thanks dave!
fla1976 04-26-2009 02:43 AM
Head gasket
I've used Hylomar but copper coat is also good. Just spray and let it tack up and then install. The Hylomar is a can with a brush and is more of a gel. If your gasket has the built in seals you don't need to use either.
russ67chevelle 04-27-2009 09:24 PM
been hearing cometics are one of the better no leaking head gaskets.thats what i run on a nitrous application and no o ringed head or block
