Nitros
Never ran nitros before do you need a seperate fuel system and how do you plum it, I no :?: about taking out timing. Any help would be appreciated. Thanks
Depends on what fuel system you have and how much you plan on spraying. You can run one pump if it is like a bg400 or a prostar 500 etc. I have ran a 300 shot on a bbc with a single bg400.
If you are not sure & have no one to help you, here is what I would do. I would buy a plate system (the one that goes under your carb). Get one that is adjustable like the NOS Cheater system. Read the instructions and follow them very carefully, plumb the car up like they say to. Use the type of pump, spark plugs, & amount of timing they recomend. Then when you are all done. Go have FUN.
TS1955 |
I'm running a 632 with two 1050 dominators and two nitrous systems. The systems are adding 700hp. I use one Magna 500 pump for the whole lot and its sweet. You need fuel regulators to get the pressure exact.
| All times are GMT -8. The time now is 08:09 AM. |
