650 speed demon help
Have a 355 chevy with a edelbrock performer package in it and vortec heads. I put on a 650 speed demon and the car has a bog when you hit the throttle for a second or 2 before it takes off. It is a vacume secondary carb should i go with a stiffer spring to slow down the secondaries.
Several possibilties:
Weak secondary spring Timing Acc pump linkage out of adjustment Bad check (the diaphragm thingy) for the main acc pump. Good luck!! |
I had the same problem with my 650 holley carburetor, it was a matter of getting the jets right and the cam pump on the side of the carburetor adjusted right. Finally after many tries I finally got it right.
Re: 650 speed demon help
650 demon help
I agree w/ dparker. Sounds like a similar situation we were having w/ the monte that I was telling you about. Except the factory distributor was the problem so he bought a new HEI dist. hooked up the vacuum advance and that cured it. Since he drives it everyday this was a good choice for his pocketbook. Kris
650 demon help
Did you get youre carb straight??? Kris
650 demon help
I guess he fixed it.
Kris |
| All times are GMT -8. The time now is 01:57 PM. |
