-   -   454 specs (https://www.racingjunk.com/forums/showthread.php?t=23900)
txhunter69 04-17-2009 08:40 AM
454 specs
ok im confused ive been told 4.25 is stock and that 4.00 is stock on my 454 which is true
chevynovaman 04-17-2009 09:19 AM
4.0 STROKE IS STOCK 454, MY 496 HAS 4.25 STROKE CRANK
obsessedtruck 04-17-2009 02:35 PM
Depends on what it is on the 454. /// 4.25 Bore, 4" stroke.
txhunter69 04-17-2009 04:50 PM
hah see this is my confusion lol
signsbyesa 04-17-2009 06:34 PM
yea stock bore is 4.25, crank is 4.00, 4.310 bore w/stock 4.00 crank
is 468, change the stroke on crank to 4.25 w/4.310 bore u got
a 496 stomper, for a factory block that is the best and biggest
bore you want to go with unless you get a merlin, and then
your car will go....whaaaaaaaaaaa whaaaaaaaaaaaa :wink:
russ67chevelle 04-23-2009 07:36 PM
bore size x bore size x stroke x 6.283=cubes
