-   -   my head swimming and confussed (https://www.racingjunk.com/forums/showthread.php?t=23876)
rhiasdaddy 04-16-2009 05:22 AM
first thanks to every one on here you all are good bunch of eggs . i understand that building a motor and what goes into it is almost a sceince with a whole lot of thought behind it . but for the first time in my 38 years i am completly lost .i have been around mechanics and motors my whole life .but i truely dont understand .what makes a bbc a stroker motor or what is a stroker motor ? are short connecting rods better than long ones ,are domes better than flat tops and cams do want a cam that opens really wide or what i dont mean to be askin alot of stupid stuff on here i just want to make a good decesions before spendin alot of money on my motor . and how does torqe factor into all of this ?do want awhole bunch of it or what ? thanks again rick
signsbyesa 04-16-2009 06:51 AM
hey daddy, no problems, the stroke is on the crank, it can make the
rod go further in the bore, hence shorter/longer rods, or shorter pistons,
a 468 has the standard 4" stroke, a 496 has a 4.25" stroke pushing
the piston further up the bore, and the rod size depends on the stroke,
and piston size, and when selecting the cam, it is best to talk to a
tech so he can give you the best cam to work with the rotating asembly.
check your local hotrod shop for a package deal or check the internet
i have dealt with www.competitionproducts.com and they are good
guys to deal with, and i would call a cam guy to get a good cam,
i dealt with www.claysmithcams.com, mr. horsepower, and
www.lunatipower.com, there are many others to choose from.
horsepower and torque complitment each other, w/o horsepower
you get no torque, with no torque you don't get down the strip.
but i have seen a motor have more torque than hswpr and torque
launches the car, its like what came first, the chicken or the egg :D :wink:
lunati makes a good crank up to 4.5" stroke forged for $825.00
they also make their own pistons and rods, good luck daddy
johnracer 04-16-2009 10:40 AM
Dynos actually measure torque and horsepower is determined by calculation. using a formula with torque and rpm. You really want to be confused, horsepower and torque numbers are the same at 5252rpm......because of the formula used to calculate hp. Applies to all engines.
signsbyesa 04-16-2009 10:48 AM
yea, and what blew my mind is a motor on horsepower tv that had
more torque than hswpr, for mountain climbing, also they recommend
a crank be internaly balanced on a stroker instead of externaly,
keep that in mind when purchasing a dampner, and thanx for the
calculations john. :wink:
curtisreed 04-16-2009 10:59 AM
Re: my head swimming and confussed
[quote="rhiasdaddy"]first thanks to every one on here you all are good bunch of eggs . i understand that building a motor and what goes into it is almost a sceince with a whole lot of thought behind it . but for the first time in my 38 years i am completly lost .i have been around mechanics and motors my whole life .but i truely dont understand .what makes a bbc a stroker motor or what is a stroker motor ? Any motor that you install a longer stroke crankshaft than was originally in the block makes it a stroker motor.are short connecting rods better than long ones , There are many arguments about that, in a bracket motor use the one that fits in the combination you are working on the best.are domes better than flat tops The less dome to get in the way of the flame front and still give the desired compression the better and cams do want a cam that opens really wide or what Your cam will have to be matched to the RPM range and desired use of the engine, that will determine the lift and duration along with the lifter type. i dont mean to be askin alot of stupid stuff on here i just want to make a good decesions before spendin alot of money on my motor . and how does torqe factor into all of this ?do want awhole bunch of it or what ? thanks again rick
Rick, just my 2 cents which is probably more than it is worth.
Curtis[/b]
signsbyesa 04-16-2009 06:37 PM
yea the pistons with domes subtract from the chamber while the
dish adds, if high compression is needed its best to get small chambers
with least piston dome to get a high compression and if the
chambers are too small the dish will help enlarge the chamber,
all that stuff is interesting, long rods, short rods, with pins going
thru the oil ring or a long piston for a short rod, interesting
and then the cam with valves springs, man when you have the
tools you can put some mean heads together, when sizing the
cam, get recommened springs, its just hot rodding, good luck :wink:
