Engine Horsepower??
I've been wondering for a while what horsepower my engine was putting out heres the specs..... 350 .060 over flat top pistons,Isky cam 510 lift 292 duration,edelbrock rpm heads, edelbrock intake, edelbrock 600cfm carb. Also its in a 70 chevelle with a m-20 muncie and 3.73 12 bolt any Idea on the 1/4 ET??
im guessin tops 400 horse maybe 415 but in that car with those gears you will prolly run anywhere frm a mid 13 to a high 12 JMO
that cam is a little small on the lift, but maybe it's me used to seeing .700 lift cams....hp maybe 350-360...good street engine tho....maybe et's hi 13's that chevelle pretty big car....good street car
I've been reading the edelbrock site and they say with a 9.5-1 350sbc they are gettin 420hp with a .488/510 lift---234/244 duration cam?? I dont know if that changes much??
dont get me wrong here....i just think that cam, carb, and your compression limit you on the flow those heads and intake can flow....350,360, even 400 hp is nothing to sneeze at....it is not going to run 9's sorry....but if you go to a larger hyd cam, maybe even a solid or hyd roller cam where the heads dcan breath and top it off with a 700 dbl pumper and bump the compression to 9.5 or even 10:1 might even 500+ out of it where it will run in the 10's....so it is up to you how fast you want to go....we are here to help if neccessary..... |
ive been looking at updating to a 750 dp and a victor jr what cam would work best with this application??
prolly like a 620 lift or around there
depending on how streetable u want ur car what stall is your tourque converter |
I'm running a 4 speed (no stall).
get that carb and intake and this cam.... http://www.lunatipower.com/Product.aspx?id=1782&gid=245 may have to bump up the compression a little but if you want to play with NOS this is the cam.... :wink: |
The way it sits now... LOW TO MID 13'S
JMO |
| All times are GMT -8. The time now is 11:12 AM. |
