-   -   bomb going off on deceleration (https://www.racingjunk.com/forums/showthread.php?t=23729)
firemanjeff 04-06-2009 10:14 AM
my motor sounds like a bomb going off when i get off the gas going into the corners i pulled the plugs and they were wet and black any suggestions where to start to fix this problem it is killing my times affraid to run it hard it sound like it is going to blow up timing is set perfect
bbchevy 04-06-2009 01:59 PM
BANG
Sounds to Me?Like the Float Level Needs to Be ADJUSTED!
That would be a GOOD start.............?
Later
G 8)
TS1955 04-06-2009 03:47 PM
I agree with bbchevy. Also check your fuel pressure, it could be over riding the floats.
TS1955
TheYellaBrick 04-06-2009 07:07 PM
Carbed or FI ?
CamBirdRacing 04-07-2009 03:39 AM
Also, your timing might have backed off.
dparker 04-07-2009 05:35 AM
You may just be slushing fuel try a hose between your vent tubes. Make sure to cut a notch out on the top center of the hose. Make sure your fuel pressure is under 7psi.
chevynovaman 04-07-2009 06:10 AM
SOUNDS LIKE TO MUCH FUEL COMING THROUGH,, JET IT DOWN, UNBURNT OR EXCESS FUEL GETTING INTO THE EXHAUST AND IGNITING.. ALSO COULD BE IN YOUR IGNITION, MISFIRES.. OPINION.. GOOD LUCK
supergass 04-08-2009 04:42 AM
It may be that it has loose headers, if the gasket is bad or burned out it will backfire through the exhaust too, even if you get the fuel mixture right.
dparker 04-08-2009 06:17 AM
X2 supergass, having your headers or exhaust to short also. But usually its not like a bomb going off more like m60s in your headers.
radicalz 04-12-2009 11:09 PM
Re: bomb going off on deceleration
Sounds like you have a bad ignition coil....what is your set for your distributor, coil......
