-   -   Water wetter, does it work? (https://www.racingjunk.com/forums/showthread.php?t=23705)
cepx111 04-03-2009 10:07 PM
Has anybody ever used that water wetter stuff in their cooling system?
Suppose to lower temps 20 to 30 degrees, just wondering if anybody else had seen that kinda of results or is it just more snake oil.
Thought I'd ask before I drop $10 on a bottle of it.
Thx, Cp
shawnp 04-04-2009 03:44 AM
I bought into the gimmick.....once.
hammertime 04-04-2009 04:12 AM
I used to run it when I ran gas stuff, actually worked for me only about 10 degrees not 20-30
suicidebomb 04-04-2009 04:19 AM
I tried it,.........took some weight off my hip. :shock:
itsabird 04-04-2009 05:13 AM
x2
tcarda 04-04-2009 06:02 AM
I agree with Hammer...10 degrees.
fla1976 04-04-2009 06:29 AM
Water wetter
I tried it and saw about a 10 degree difference.
kwkracing 04-04-2009 10:43 AM
Does not work and by the way kitchen soap is cheaper if your gonna do it
suicidebomb 04-04-2009 11:39 AM
Yep, all that stuff does, is break the surface tension of water. Soap does this very nicely.
johnracer 04-04-2009 02:08 PM
Yep, same here.......
