neutral safety switch
I GOT A HURST QUARTER STICK FOR MY POWERGLIDE CAN ANYONE TELL ME HOW TO WIRE THE SAFETY SWITCH SO I CAN PASS TECH AT THE TRACK THANKS.
take your start button wire that would go to the starter
to the neutral switch first then to the starter/solinoid there are two poles on the neutral switch, after you hook it up the motor should only start in park,..if it starts in gear or reverse switch the two wires on the Neutral safty switch. |
ok thanks for your help.
| All times are GMT -8. The time now is 09:03 AM. |
