-   -   bbc balance question (https://www.racingjunk.com/forums/showthread.php?t=23664)
taps 03-31-2009 05:02 PM
i have a internally balanced 468 chevy,am getting a dart block and going 4.5 bore,old pistons weighed 587 new ones weigh 618, should i rebalance?
slickfuel 03-31-2009 05:46 PM
Its pretty close but......I would,.. its all apart,....
hammertime 03-31-2009 06:16 PM
Re: bbc balance question
Yes not close enough for me
hink 03-31-2009 06:24 PM
Now your crank is under balanced which is not a good thing over balance that much would be fine 31 GRAMS under balanced is a lot!!!!!!!!!
chevyfireball 04-02-2009 04:15 AM
Yep, definitely balance that thang
radicalz 04-03-2009 01:44 PM
Get it balanced while it is apart wont have any headaches later :wink: :wink: ...balance the whole assy, crank, rods, pistons, balancer and flywheel
ashbros 04-13-2009 11:58 AM
Which weighs more 25 lbs of wet sand or 25 lbs of dry sand.
They weight the same,
Your new pistons don't.
I would most definately get the rotator balanced.
