-   -   Calculating Compression (https://www.racingjunk.com/forums/showthread.php?t=23651)
jreiley 03-31-2009 04:23 AM
How can a compression reatio be calculated for a blown engine with 10lbs of boost and a starting ratio of 8.5 to 1.
TS1955 03-31-2009 10:06 AM
Give specs on engine. Bore, stroke, rod length, & cam specs. mainly valve timing.
TS1955
zipper06 03-31-2009 02:38 PM
Re: Calculating Compression
Here you go, there are also calculators for anything else you want to figure.
http://www.wallaceracing.com/dynamic-cr.php
