-   -   MANUAL BRAKES,HELP!! (https://www.racingjunk.com/forums/showthread.php?t=23650)
JEFF69Z28 03-31-2009 04:22 AM
I HAVE A MP BRAKES CONVERSION FOR MY 86 MONTE CARLO WHEN I PUT THE MASTER CYLINDER ON THE CAR THE PUSH ROD THAT COMES WITH THE KIT IS 1/8 INCH OFF CENTER, IM USEING THE TOP HOLE ON THE BRAKE PEDAL.WHAT SHOULD I DO TO SOLVE THIS PROBLEM.
radicalz 04-12-2009 11:23 PM
Re: MANUAL BRAKES,HELP!!
Are you converting from the original set up of power brakes to the MP set up?....does it have a booster?...1/8 inch off center is a bunch...make sure the rod is not bent...put it on a flat surface and roll it...does it wobble? then it is probably bent...call MP tech line tell them what your problem is they should be able to help you or find a new one...
